JD 544 Loader
Ethan Jones
04-30-2007 17:27:05
My grandfather has a JD 544 articulated loader, and the engine started knocking while we were using it about a year ago. We just parked it, and it is still settig in the same spot. I am trying to find out what engine it has in it so maybe I can find one to swap into it. It is a plain 544, not an A or B series. It is a non turbo diesel, and the engine tag says 63HC. I cant find the serial number tag on the machine, but if anyone knows where to find it...Any help to ID the motor would be great. Questions, comments, suggestions appreciated.
Mike M
05-01-2007 11:43:29
 Re: JD 544 Loader in reply to Ethan Jones, 04-30-2007 17:27:05
Why not just rebuild the one you have ? Who knows how good of one you will find used ?
720 in pa
05-01-2007 03:23:24
the early 544 had the 303 cubic inch engine,unless it has been repowered,altho most 329"s have the tag marked as 329
Glen in TX
04-30-2007 23:31:36
The 329 was used in lots of industrial equipment and tractors and parts from JD and short blocks are available. http://jdparts.deere.com
Glen in TX
04-30-2007 23:18:42
See online parts catalog. Could have been a 303 or 329. 329 was also used in 4030 tractor and some 6600 combines but block and mounting holes could be different.
430WLPG
04-30-2007 18:26:41
I beleive the 544B had a 329 and that maybe what you have
