4020 Hydraulic Outlets Leaking
MaverickM23
04-30-2007 14:44:12
I noticed today that one of my rear hydraulic outlets is leaking. When I look underneath it there are drops of oil that collect on the bars that lock the hoses in the outlets. Plus the frame is stained with oil. Is there a rebuild kit that addresses this or what should be done. Thanks
msb
04-30-2007 19:13:35
 Re: 4020 Hydraulic Outlets Leaking in reply to MaverickM23, 04-30-2007 14:44:12
Remove the complete break away coupler from the tractor and place it on a workbench. I use an old broken punch ground to a sharp point. Drive the sharpened punch into each freeze plug on a fairly flat angle. Then pry the plugs out.Use a pick to remove the E clips holding the levers in. Careful--- those little springs like to fly out of there and hide from you.Push the levers out the bottom. You can now push the coupler barrels out the back. Note the flat spot where the spring and lever went and replace it in the same position or you will never get the thing back together.Slide the coupler ball retainer ring back and catch ALL the balls. They like to jump off the bench and hide too. I then wash all parts in mineral spirits ands blow them dry.Remove and replace with new o-rings and back up washers like they came out. There are two for each barrel in the housing and two for each lever.Yes , those back up washers can be a bicht. Some people put them in first. Others find it eaaier to install them after replacing the o-rings. It depends on what kind of mood I am in. Sometimes I do it one way and sometimes, the other way. At any rate they go in a lot easier if you use lots of grease and make sure they are not overlapped or they WILL leak. Use a pick to push them in place after the o-rings are in place. I use wheel bearing grease to keep those pesky balls in place. Carefully push the barrels back in place with the flat up.Reinstall the levers and then-----the fun begins. Getting that E clip on place while holding the spring down.I made a tool by cutting one side(about half) of a small piece of metal tubing and and cut the tubing on a slight angle to it can be tipped back out of the way, the spring is then pushed down and the E clip pushed in place. That was until I saw how thay did it on the assembly line in Waterloo.They took an E clip tool and bent it in a step like fashion. Put the clip in the tool. Push it down on the spring and slip it in place.So simple and I fought those crazy thing for more times than I can remember
Brent in WI
04-30-2007 18:46:03
I replaced all my seals and upgraded to ISO couplers on my 3020 last year. If you're going to do this make sure you replace all the seals. Sometimes the kits for some reason don't include all the seals. It is a little more work but I would take them off the tractor to work on a bench versus being on your knees or bent over for a long time. Give yourself two to three hours and make sure you have a clean surface and good lighting. The main inner o-rings and backup rings are a little hard to do. If you don't have a set of o-ring tools they are definately worth the $10 to $15.
MaverickM23
04-30-2007 19:10:24
 Re: 4020 Hydraulic Outlets Leaking in reply to Brent in WI, 04-30-2007 18:46:03
What is the difference between the ISO conversion and the normal outlets? I take it they are just a newer design but was just curious
Gerald J.
04-30-2007 21:54:46
 Re: 4020 Hydraulic Outlets Leaking in reply to MaverickM23, 04-30-2007 19:10:24
ISO tips hold better than the old Deere tips. And are used on most tractors today of any make. Pioneer 8010 is the ISO tip. ISO tips won't fit Deere outlets and Deere tips won't it ISO outlets.
Gerald J.
MaverickM23
04-30-2007 19:01:07
The kit I was looking at is AR82570. Now it also lists some other O rings, Early and old design and other seals. Heres the link to the diagram Link
JD@Antique Acres
04-30-2007 16:52:23
Deere offers a seal kit. Also check the RECEPTACLE part#R34397 for wear and or cracks. I had to replace both to solve the problem.
MaverickM23
04-30-2007 18:03:16
 Re: 4020 Hydraulic Outlets Leaking in reply to JD@Antique Acres, 04-30-2007 16:52:23
I'll check them out. How hard is it to tear this apart? Looking at the part diagram shows alot of small parts, Im just tired of these things leaking.
