I'm not sure having a DLTX71 carburetor necessarily means that the tractor was originally equipped with an automatic fuel shut-off. Any A's I've seen with those had them installed years later, after they were introduced in the 50/60/70, and as a result, many still do not. If you have/had the automatic, oil pressure activated unit, rebuilding it with a fresh diaphragm almost always fixes things fine. On the "turn-it-until-it-seats" manual sediment bowl valves you buy these days, sometimes it helps if you polish the valve tip with some "wet" 1200 sc cloth. Same goes for the float valve in the carburetor, if not rubber tipped, to ensure that no "flash" is left over from the die cast process, chuck it in a lathe, or drill press, or even in an electric drill and polish it with wet 1200, or a shop rag holding some medium grit valve grinding sc compound. If you want, after it's polished, you can try to lap the needle and seat together. That most always solves the problem of the drippy float valve. Then again, it could have been as simple as a piece of grit that held the needle valve open and it might never happen again, but if you wonder, let the carb bowl drain valve open and put a funnel and can under it, and make sure it stays dry. If it leaks, the gas is lost anyway, and it's better if it's not in the oil. Anyway, that way you will know if it's tight at the sediment bowl, which will hold the fuel back from the carburetor, AND that the needle valve will hold fuel back over a long lunch, or a "forgot-to-close-the-shut-off-valve-last-night" incident. You need both points of retention to work, but you do still need to remember to shut the fuel off at the tank. Frank
