4455 digital speedometer
Mostly Green
04-29-2007 19:27:29
While planting the other day, my digital speedometer all of a sudden went from 3.7 to over 6 mph while traveling in 6th gear on a power shift trans. I checked the actual speed and ,sure enough, it indicates a speed on the speedometer much faster than actual travel speed. The speedometer still indicates "mph" and not some other scale ( Km/hour, knots, ..... ..) This has me puzzled. Do you have any ideas? This 4455 does not have the radar. Thanks! Happy planting!!!!
mattd
04-30-2007 19:06:07
 Re: 4455 digital speedometer in reply to Mostly Green, 04-29-2007 19:27:29
if your tractor doesnt have radar then the hall effect switch is going bad. on 15 speeds it is located above the rear trans filter kindve up and to the right. its a 2 pin connector. its just got a clamp holding it in.
G/MAN
04-30-2007 07:39:19
Wheel speed sensor, more than likely. Another possibility is an issue in the display itself. Start with the sensor.
Tx Jim
04-30-2007 04:00:23
I would guess that the MPH sensor has gone bad. Tx Jim
