G/MAN
04-29-2007 14:16:28
Re: 4760? in reply to GG75WW, 04-29-2007 11:30:03
That asking price is pretty darn reasonable, if you ask me. If it's in good shape with those hours, I'd expect it to be listed for $6000 to $8000 more around these parts, if not more. But we have very few Quad-Ranges around here, so powershifts are the norm and command more $$$$. We've got way more 49s around here than 45s and 47s, but there are some of the smaller two tractors, and the 4760 is a good horse top to bottom. 200 hp sounds about right. Most 45s run in the 180-hp range and most 4960s will knock down 220 or so pretty easily, so you're right in the ballpark. Reliability-wise, 10,000 is definitely possible without major failure if the tractor has been properly maintained and operated in the past and you take care of it also. As good as your 4450 is, that 4760 is so much more tractor you won't believe it - better cab and controls by a fair margin, obviously a large-frame vs. a small-frame, electronic hitch, etc. They're also pretty easy on fuel for that size of tractor. I don't know about the 4760, but the 4960 set a new fuel economy record at Nebraska when tested. There's not much I don't like about the 60s, except for serviceability on the engine is a little "different" with the side exhaust than it is on the 50s and 55s. Note I didn't say "worse", because I tend to like the exhaust system, and when you want it out of the way, such as for adjusting valves or servicing the nozzles, it's relatively easy and quick to remove the whole thing (muffler, down-pipe and stack) as one big chunk and set it off to the side. One thing I'd recommend looking into is the rear main crankshaft seal. When the 50s came out, Deere changed from the cast-iron rear main seal retainer to an aluminum unit, and on a lot of engines with that retainer, the seal for some reason will "suck in" and allow engine oil to transfer to the transmission. You may have run into this issue, owning a 4450 as you do. Not a big deal if you keep a good eye on oil levels, but I worked on a 4960 that did that, the oil level wasn't watched and the operator decided he could continue driving across the field when the oil-pressure and "stop" lights came on, which resulted in a spun #4 rod bearing and a $10,000 overhaul with a new crankshaft. If the seal does start leaking, the tractor will have to be split to replace the seal and retainer. Deere has another new seal design that supposed to stop this problem for good, so we'll see. Apart from that and the normal checks you want to make on a used tractor, you shouldn't have any other major issues. I'd maybe insist on some sort of "inspection" by a qualified mechanic before purchasing just to look for things you might not otherwise notice - maybe check hydraulic system and tranmission pressures, check for wear at the front axle spindle bushings, pivot pins and bushings, final-drives, etc. Years ago I wrote some articles for Tractor Shop magazine. One on what to look for when purchasing used 30-60 series Deere tractors and later one on the large-frame 55- and 60-series Deere tractors themselves, both of which I consider to be pretty darn informative and helpful, if I do say so myself. They might be available in back issues.
