Bean Planter
Larry806
04-29-2007 08:25:22
Last night we took off the seed boxes to check the units , turns out they are all worn out . Nothing left to rebuild . I need 15 bean units . I found 15 used Kinze units for 750 I'll have to find 3 more or should I look in to the Deere radial meters? What do you guys think? Thanks for any replies .
Glen I don't know it you saw my reply but it is a 7100 . Do you want to sell the manual you have ? . Last
Larry806
04-29-2007 12:08:45
 Re: Bean Planter in reply to Larry806, 04-29-2007 08:25:22
That should have said I found 12 Kinze units . I need 3 more . Glen I sent you a email .
Glen in TX
04-29-2007 17:06:30
 Re: Bean Planter in reply to Larry806, 04-29-2007 12:08:45
Email headed back at you.
Glen in TX
04-29-2007 10:30:55
Hi Larry, I saw Mike's comment about it being a soybean special but manual shows all 12 row 7100 could have option of high lift assist wheels. Your first pic should have tipped me off too it was 7100 and I was wondering why you had lift assist on a 7000 like that lol. I have a dealer service shop copy manual with pink cover and is apparently a updated copy for planters 1980 and later. OM-A40638 Issue D0 plow & planter works for 71100 max emerge integral planters. It does show the 12 row soybean planter with dual guage wheels, lift assist, standard planting charts, and how to tie it down on Donahue implement carrier JD sold with them back then. Email is open if interested in manual.
Mike Aylward
04-29-2007 20:13:46
 Re: Bean Planter in reply to Glen in TX, 04-29-2007 10:30:55
Glen, the main reason I thought the planter was a Soybean Special was that it appeared the rows were set on 20". The later 7100's had the over the top wheels as well but I thought the two together probably made it a SS. No damage done..:) Mike
Glen in TX
04-29-2007 21:17:16
 Re: Bean Planter in reply to Mike Aylward, 04-29-2007 20:13:46
Okay well I didn't even know there was a soybean special and the narrow rows weren't done around here until last 10 years or so with corn guys south of here. JD Publications shows a different manual for soybean special and I had no clue why really so thanks that explains more.
JD Jim
04-29-2007 09:02:31
I like the kinze brush meters. I think theyre cheaper too?
