Fuel Transfer Pump
backwoodsfarm
04-29-2007 06:10:50
I have a 2555. Had to rebuild the fuel pump because it was leaking around the pump gasket. Installed it and ran it for 10 hours or so and put it away for the winter. Went out the other day and started it up with no problems and that fuel pump started leaking fuel like crazy. Are you supposed to use permatex or some type of sealer on those gaskets when you rebuild one of those? I wasn't sure and didn't want to contaminate the fuel. Thanks.
Glen in TX
04-29-2007 10:49:27
 Re: Fuel Transfer Pump in reply to backwoodsfarm, 04-29-2007 06:10:50
You could use permatex on on gaskets but don't get it on the diaphrams if it's that type of pump. Gaskets next to diaphrams if that type shouldn't need sealer but yes on the pump to engine gasket use some sealer. Maybe gaskets were old or bad and check for flat non warped surface on pump with straight edge too. Permatex high tack or aviation sealer with a brush in can should work well.
