Bad day plus 2 questions.
RAH
04-28-2007 17:27:09
Got the leaf blower to clean off driveway, bogs down, dumped old gas and added fresh, same problem, swiped plug from chain saw, (Oh shucks, someone's been in the dirt with the new chain) probably me, blower still as boggy as an old mule. Hauled stuff off to get it serviced, I stopped monkeying with 2-cycles in '63. Had fight with wife, no that was yesterday. H's portable Generac with an "idle down" has now caught the cold from the leaf blower, same treatment and lack of success as I had with the leaf blower. Switching on a saw kills the engine at idle or full trottle.
Now I'm ready to put a coil on a slant dash A, let's check the AR and B. One has the top plug wire going to the left plug, (I think this is correct), on the other the top wire goes to the right plug. Am I correct in assuming that I have to remove the distributor and rotate it's shaft 1/2 turn, re-install and re-time the tractor?? On one of these tractors the wire from the ignition goes the + coil terminal and on the other it goes to the - terminal. Am I correct that the wire from the ignition switch (switch is connected to the negative battery terminal) should go to the positive terminal of the coil? On the new coil the primary, secondary and case are electrically isolated from each other. Does the polarity of the secondary affect the tractor. Both tractors run excellent and start on the first or second stroke. Thank's in advance for any response. With my luck today I'm not sure I could tell nositive from pegative even if I could find my physics book from the '50's. Sorry about the long rant.
RAH
04-30-2007 12:15:18
 Re: Bad day plus 2 questions. in reply to RAH, 04-28-2007 17:27:09
Thanks, fellows for the suggestions. I looked at the nut holding the muffler on and know about carbon, but it never clicked. It does get fed the prescribed mixture, I have driven 2 miles into town to measure the exact quantity of gas. Ran good last fall, but it may have been set near the entrance door to the shop last fall and filled the muffler with those Japanese beetles.
Ken L.
04-29-2007 15:03:32
This may sound stupid but, on your leaf blower, make sure that the muffler isn't getting plugged. I've got a weedeater that was doing the same thing. Checked the carb, installed a new plug, didn't help. Took the muffler off and it was all carboned up. Cleaned it and it runs great even though it's about fifteen years old.
Jim Benson
04-30-2007 06:57:54
 Re: Bad day plus 2 questions. in reply to Ken L., 04-29-2007 15:03:32
Ken, not at all stupid, had a Lawn Boy that would do the same thing. The stupid part is (I think anyway) that the build up occurs because someone (not me, of course, haw) measures the oil by eyeball and it doesn't completely burn.
Paul from MI
04-28-2007 17:51:53
Hope I can help. Know what you mean, but any day your feet are on the green side of the grass ain't too bad.
As far as the plug wires go, the top wire should go to the left cylinder, but unless you are bothered by it, I wouldn't change. If you are, then rotate the distributor 1/2 turn, re-install and re-time it.
The polarity of the coil should match the polarity of the electrical system. These were all originally positive ground systems, but many have been changed to negative griound over the years. If the battery is positive grounded, then the + side of the coil primary should go to the distributor. If negative ground then the - side of the coil should go to the distributor. Many tractors will run OK hooked up backwards, but you'll have hotter spark if it's right.
Good luck,
Paul
