The oil filler for the 50 sits next to the bottom of the clutch lever, on top of the 1st gear reduction case on the right side of the engine. The cap is about 2 inches in diameter and is threaded and has a raised section along its back to allow you to use an adjustable wrench or pliers in case its stuck. Directly under the engine you will see a large hex nut that holds the oil filter cover in place. This cover is about 3 inches in diameter. Next to the cover you should see a square threaded "plug". This plug is the engine oil drain. To fill you simply pour the oil in the filler inlet. There is no dipstick. There is a little check valve on the side of the engine near the big pully. You will noice a long thin threaded nut and next to it there is a larger one. The larger one is actually a plug. Unscrew it. When the engine crankcase is full, oil will run out this port. Screw the plug back in once you see oil running out. I've been using filters from John Deere and 10-40 Rotella-T engine oil from Shell (available in many auto parts stores). My 50 takes something like 7 quarts of oil with the filter change. When you change the engine oil don't forget to pull the bottom off of the oil bath air cleaner. Clean all the dirt that has accumulated in the cup, then refill it to the "full" line with engine oil. Best of luck with your 50, its a great little tractor. John 1953 Model 50
