4230 starting
Gene-Wi
04-28-2007 14:05:18
I was at an auction with my neighbor and the owner used ether to get a 4430 started, I said must not be in very good shape if it needs ether when its 50 out. My neighbor said his is the same way, below a certain temp. he has to use ether, but not all the time. Seems like I remember someone telling about a certain procedure to shut them down and they will restart better. I searched the archives but couldn't find anything. Any one know what I'm talking about? Thanks, Gene
buickanddeere
04-28-2007 17:44:09
 Re: 4230 starting in reply to Gene-Wi, 04-28-2007 14:05:18
Slow cranking rpms are the main problem. A destroker on the hydraulic pump helps. HD 2/00 welding cable with swaged on connectors, low resistance connections and two high CAA batteries are required. Odds are that starter is only receiving 7 to 8 volts while cranking.
Tx Jim
04-28-2007 14:38:38
Gene,if you're inquiring about a tractor with a Bosch "piston Inj. pump" then after killing engine,push throttle full forward then return to idle. This sets rack inside inj. pump to start position. Also if pump has mechanical aneroid then before attempting to start trip linkage to forward. As far as I know no 4230's had this type inj.pump from factory. Jim
