john deere 2350 left-hand draft link leaking
Juan Raygoza
04-27-2007 19:05:29
the left hand draft link started leaking as it warmed up after a hard winter here in utah, the leaking is right in the connection between the load control shaft and the left hand draft link, Im trying to take off the draft link to replace the gasket, but there is a pin that crosses a bushing and the load control shaft and keeps the draft link in place, but the pin is way stuck, i removed the spring that holds the pin in place, I put half bottle of wd 40 and I have been hitting the pin not so hard trying to make it move, but nothing, and the leaking keeps going on, should I drill it? and put a new pin? or can I hit it harder without messin the load control shaft? any suggestions? please help, thanks
Tx Jim
04-28-2007 04:35:12
 Re: john deere 2350 left-hand draft link leaking in reply to Juan Raygoza, 04-27-2007 19:05:29
You will need to renew seals on both sides so why not see if pin on opposite side is free and remove shaft that way. Drain oil before removing shaft. Tx Jim
juan raygoza
04-28-2007 22:22:45
 Re: john deere 2350 left-hand draft link leaking in reply to Tx Jim, 04-28-2007 04:35:12
I already tried right side, but they are both stcuk, I bought the tractor las year,and it seems like they never took them out before, can I drill them, and then replace the pins with some new ones?
Tx Jim
04-29-2007 03:06:20
 Re: john deere 2350 left-hand draft link leaking in reply to juan raygoza, 04-28-2007 22:22:45
I've never seen pins stuck that much in a L/D shaft. I suppose with a good bit one could drill them but I'll bet they are made of hardened metal. Have you thought of using some heat? Tx Jim
Juan R
04-29-2007 21:55:09
 Re: john deere 2350 left-hand draft link leaking in reply to Tx Jim, 04-29-2007 03:06:20
I tought about using some heat, but I tought it would be a little risky, because all the oil is leaking there and the grease and flammable stuff thats close, you think I would be safely fine? I would like to try that before drilling them
thanks for your support
