36' B fan blade rubber
JDNPC
04-27-2007 15:30:24
alrighty, i have tried my best to come up with a plausible answer to my own question, but to no avail, i am beckoned back here to the jd forum. let's see if anyone else can drop there two bits in here to help me out. after disassembling the fan blades on the end of the shaft, {i had to do this becaue my 36' had two opposing blades cut off and the 37' parts tractor had the same thing,}i put a complete fan blade assembly back on the rubber collar made of the two units. it fits good, but you can slightly rotate the blade housing on the rubber. is this normal, or just severely worn ? it seems like it will walk alittle out due to rotation, and i don't want to be buying a replacement radiator if it doesn't hold up. i was thinking of putting some rubber tape that is an 1/8 inch thick around the peak of the rubber collar and then reassembling the blades to snug it all up. unless anyone has any better idea, or is this normal ? i will say that when i turn the fan blades by hand, i can grab the shaft and spin the blades slightly, and pull it forward about an 1/8 inch also. the rubber is not moving on the collar though. does deere offer a replacement rubber collar assembly ? thanks in advance fellas....and ladies.....
WeirdDeere
04-28-2007 02:24:43
 Re: 36' B fan blade rubber in reply to JDNPC, 04-27-2007 15:30:24
Deere stopped making the rubber hub fans during the war if I remember right, due to rubber shortages, and the fact that the rubber can "let go" and let the fan meet the radiator. I don't think anyone has parts for these. There was also an update kit at one time to the clutch type... You would be better off to find the clutch style fan parts and dump the rubber hub.
Brandon
Mike M
04-27-2007 17:16:08
If that rubber is deteriorated any at all letting it move you better find another one.
Maark
04-27-2007 16:24:44
Throw that rubber hub mounted blade as far as you can. The rubber deteriorates and the blade will go through the radiator or even worse, maybe you, if you happen to be standing near it when it comes apart.Most fanshafts have been updated to the new style with the friction drive disk set up.
