1968 ,1010 special
Roy in georgia
04-27-2007 14:36:05
I loaned it & box blade to friend.I got it back and the govinor dosen"t work.
buickanddeere
04-27-2007 18:35:48
 Re: 1968 ,1010 special in reply to Roy in georgia, 04-27-2007 14:36:05
No such thing as a 1968 1010. What is the serial number a sparts vary? Gas or diesel?
Roy in georgia
04-28-2007 20:05:48
 Re: 1968 ,1010 special in reply to buickanddeere, 04-27-2007 18:35:48
Father in law said he thought it was 1968.I will get #s & post new
Bob
04-27-2007 14:52:43
Define "governor does not work".
Does it "overspeed"?
Does it fail to "pick up the load?
Does it fail to rev the engine above idle when the throttle is opened?
Roy in georgia
04-27-2007 15:02:25
 Re: 1968 ,1010 special in reply to Bob, 04-27-2007 14:52:43
engine speed remains set. It does not increase with load and causes engine to stall. Also what makes it (special) 1st tractor = 1st lesson DO NOT LOAN TO FAT BOY.
Bob
04-27-2007 15:06:17
 Re: 1968 ,1010 special in reply to Roy in georgia, 04-27-2007 15:02:25
Dirt, water, or other restriction in the fuel system will cause the engine to falter under load, rather than "pick up the load". Could this be your problem, rather than governor problems?
Roy in georgia
04-27-2007 15:32:42
 Re: 1968 ,1010 special in reply to Bob, 04-27-2007 15:06:17
I forgot the hood is off so I can see the gov rod and I don't see movement
Roy in georgia
04-27-2007 15:12:45
Bob I don't think so new bowl w/little sediment in it I can change engine speed manually for higher revs. and maintain it without stalling.
