1967 JD2510 Gas With Starting Problem
Dave Wicks
04-27-2007 14:04:26
Never had a problem until removed from everyday farm service about 17 years ago. At that time engine stalled because of what I thought was simply running out of gas (fuel gauge hadn't worked accurately for some time so I wasn't sure this was really the problem). After adding gas, tractor started a ran normally for awhile. However, at times engine would begin to stall and the only was to recover was to be quick on the choke. If it did stall, it usually could be started again if coasted to level ground. The tractor received a carburetor rebuild and a new fuel pump. New fuel filters were installed and a complete ignition overhaul was performed. The fuel system was drained and replaced with fresh gas. The used(two year old)tractor came with an electronic valve on the base of the carburetor to shut-off the fuel flow when the ignition switch was turned off. Its purpose is to keep the engine from "dieseling". The original valve needed to be replaced several years prior, and due to expense, a cheaper manual valve was used for about a year until the dieseling got to me and a new electronic valve was purchased. Thinking the current problem might be caused by this valve becoming defective I tried using the manual one again but saw no real difference. The tractor which is stored inside last ran two years ago. Following long battery cranking, it started and ran alright for about five minutes before cutting off and stalling. After a few times I gave up. Last year it wouldn't even fire. I could smell stale gas so I'm sure this will need to be replaced with fresh. I'm concerned that the engine will set up if I don't get it running soon and plan to go back at it soon. If anyone has any advice on where to begin and follow through on correcting this problem it would be very much apreciated. When this was the biggest and newest tractor on our farm, it gave hours of reliable, uninterrupted service performing numerous jobs.
Glen in TX
04-28-2007 10:03:48
 Re: 1967 JD2510 Gas With Starting Problem in reply to Dave Wicks, 04-27-2007 14:04:26
Agree with Bob's comments below especially checking ignition right after it dies. Check voltage at your coil then too. What shape are batteries and rest of electrical? Battery cables, connection & wiring. May still have crud in tank and how clean is fuel coming out of tank and is there a steady flow of fuel to pump and from there to carb? Carb probably needs to be done again with all jets pulled and passageways cleaned out. It doesn't take much varnish or trash to plug up the solenoid needle valve either and easily cleaned again with spray carb cleaner.
Bob
04-27-2007 14:56:59
It sounds like either junk/crud/water restricting the full flow of fuel from the fuel tank to the carburetor, or a flow restriction IN the carburetor itself.
Also, check for a weak spark when it shuts down. A bad coil can heat up and get weak after running a little while.
