4020 starting problem....relay question
nwjerry
04-26-2007 20:05:26
I kept my dad's 4020 after his death ,little on the rough side but I am trying to get it going. Serial # is over 207000 and has relay located before starter. I remember this relay being trouble many times. I see 4020's that do not have this relay. What is the purpose for this relay and can it be by-passed without causing major problems. Tractor will not start, nothing happens when ignition keyed.
I suspect the relay. Any info appreciated.
Nylon
04-27-2007 15:55:46
 Re: 4020 starting problem....relay question in reply to nwjerry, 04-26-2007 20:05:26
I will add one thing since it happened to me. Jiggle the nuetral safety plug a bit. If you can jump the relay and get tractor to start with a screwdriver it is a possibility. Make triple sure tractor is in park. That nuetral safty switch is tough to reach and clean up the contacts.
jdemaris
04-27-2007 09:41:07
The extra relays were sometimes used on 4020s with aftermarket cabs. Deere used the OEM on several later 4020 sized tractors. The main reason for the relay is the ignition switch and current capacity. Most of the switches are only rated 20 - 30 amps. Not a problem with small-frame stater-motors like you'd find on a 1020 or 2020. But the 4020, 4230, etc. use large-frame starters the larger starter-solenoid can sometimes draw - or surge close to 20 amps. When hooked directly to a standard ignition switch or push-button - that gets a little worn - it can cause a problem. Using the extra relay in-between takes the load off the ignition switch. Depending on the relay type, it can also make it easier to add extra safety interlocks.
Bob
04-27-2007 06:55:33
Are you talking about the large circuit breaker that protects the wiring harness, or an actual relay (car-type starter solenoid)?
The current from the key switch or starter button takes a long path to the LARGE starter solenoid, first to the neutral-safety switch(s), and then on to the starter. This long run, combined with switch(s) and connectors causes voltage drop, so the BIG starter solenoid doesn't get all the current it needs to engage properly.
The additional relay takes less current to operate than the solenoid on the starter, so it is connected AHEAD of the starter solenoid, switching the higher current needed by the starter solenoid.
msb
04-27-2007 06:38:27
Its on there to protect the whole wiring harness. A very few of the older models would short out on their own and cause the wiring to burn up. I had a neighbor who had his 3020 parked near his bedroom window. Woke up at 3 o-clock in the morning to hear the starter cranking. He thought someone was trying to steal the tractor. Turns out the wiring shorted out and cause the starter to engage. Just replace the relay.They are not that expensive.
nickg
04-27-2007 06:07:10
I am sure you have checked all the usual things, batteries, connections and such. I have an early model 4020 that has circuit breakers. Luckly I never have had problems. They have saved me from burning up my starter though. my experienc with that stuff is it is there for a reason. I would also check the key switch. If it has sat for a while the terminals on the switch can become corroded and short out your key switch. hope this has been some help
