REsults DeRust Carb with 12 Volt charger
Ben.So.Tex
04-26-2007 18:14:47
Well it cleaned the carb fairly well.. It crusted the Neg cable that was just stuck in the water,( cleaned it twice in the 18+ hrs I had it in thier) and the positive cable attached to the carb it was fine. It might of had a different effect if I would of used baking soda. I did look in the archive for some info.
Thanks to all who replyed....( I was looking for your info on it F-I-T. from the results you had with your 70 I think.) (12volts @ 6 amps)
Later Ben
gurneejoe
04-27-2007 05:21:54
 Re: REsults DeRust Carb with 12 Volt charger in reply to Ben.So.Tex, 04-26-2007 18:14:47
It sounds like you have the polarity backwards. The positive should be on the electrode and the negative on the part. Wrap a piece of wire on the part and suspend it in the water so your charger leads don't get messed up.
F-I-T
04-27-2007 14:09:46
 Re: REsults DeRust Carb with 12 Volt charger in reply to gurneejoe, 04-27-2007 05:21:54
"gj" is exactly right. It sounds as though you didn't even use a sacrificial electrode, just depending on the steel in the cable clamp to provide a bit of conductivity. The surface area of electrode should be greater than or equal to the surface area of the part to be cleaned. As reaction progresses, the electrode will turn red and the part will turn black wherever red rust was present. SO, the easy way to remember the polarity is to think that you want the red cable to hook to the part that will turn red, and the black cable hooked to the item that you want to turn black. ;)
billde
04-26-2007 19:50:37
You want Washing Soda, not Baking Soda.
