60 thermostat
Bob with a 60
04-25-2007 19:17:31
WOW I just priced a thermostat 1954 model 60. Had to price itfromJohn Deere as could not find a replacement anywhere else. The part # is AA5750R .goes into a housing on top of block # A4951R and another housing goes on top of that to connect to the upper water pipe to the radiator #A4952R1 not sure the last 1is part of part number or not on that one. Does anyone know of an aftermarket thermostat for this. There are alot of different ones that could fit a 60 . John Deere is at about $117.00 For the dang thing ! Tryed one from napa that it calls for and its way to thick to fit in between the housings. About 1/4 inch and the one I need is only about 3/32. Tryed all the other aftermarkets I know of and they just can't seem to get that one. Its 2 7/8's inchs across
Bob with a 60
04-27-2007 07:43:11
 Re: 60 thermostat in reply to Bob with a 60, 04-25-2007 19:17:31
Well we have that problem solved,a good parts man at napa helped out. He sold me a 374-180 thermostat that just almost fits in the housing,took it home and took the belt sander and sanded of about 10 thousanths of it and it set right down it the housing. Was 10 thou to big around. Cost 32 bucks ,lots better then the 100 plus from JD . The thermostat is for an Isuzu diesel so its a big heavy duty one.
john IH
04-26-2007 09:06:41
try Triple "G" service in Alden, New York.
1-888-720-0830 0r 716-542-3175
this is where i got mine from. it was cheaper than deere. that was 2 years ago.
john
Mike M
04-26-2007 07:00:53
Would it be possible to turn down the NAPA one or use a thicker gasket so it will fit ?? I'd have to see the exact situation I guess ?
