4620 Radiator
HJ
04-25-2007 18:57:07
Doing some work on a 4620 and trying to figure out why the overflow is puhing out water at idle.
I drained the radiator and stuck a garden hose in the top and water runs out the bottom. So I put water back in it and drove it around a while and got the temp gauge up about halfway and noticed that the bottom radiator hose was still cool. The top one was hot and tight with pressure. I took off the cap and the water in top was too hot to touch but the water at the bottom was just luke warm. Is something still wrong with my radiator or is it the water pump, or what about a head gasket? It seems to bubble in the radiator a lot.
Mike M
04-26-2007 10:00:28
 Re: 4620 Radiator in reply to HJ, 04-25-2007 18:57:07
Hook a pressure tester on the radiator and then start up the tractor and watch that gauge. If it is a head gasket you will see it really fast as that gauge builds pressure. Be ready to shut it down because if it is that pressure will build up too high too fast and get over the danger zone.
Jim Presley
04-25-2007 19:40:23
Hot on top and cool on the bottom is no water flow. It is either the thermostat stuck closed, or a water pump that is not turning. Broken pump shaft would do the trick. Got to be thermo or pump.
Let us know what you find!
Jim P
HJ
04-26-2007 10:56:32
 Re: 4620 Radiator in reply to Jim Presley, 04-25-2007 19:40:23
Where do you think the bubbles are coming from? That is what makes me think I also have a head gasket problem. I am doing a compression check on each cylinder tonight to see if the gasket could be bad. If they check out ok then I am going to pull the radiator and water pump.
Jim Presley
04-25-2007 19:43:39
Actually, stuck thermo would not even give you hot water at top. Must be pump or complete blockage in lower hose.
msb
04-25-2007 19:08:26
Sounds like the radiator is plugged. Take it off and to a radiator repair shop and have it flow tested.
HJ
04-25-2007 19:10:09
 Re: 4620 Radiator in reply to msb, 04-25-2007 19:08:26
If I put water in the top it comes out the bottom right away. Where could it be plugged?
msb
04-26-2007 05:33:21
 Re: 4620 Radiator in reply to HJ, 04-25-2007 19:10:09
Probably enough cores not pluggrd to let the water pass to the drain, but plugged enough so you get very little cooling.That is why you need to get it flow tested.
