Help Starting a 1936 A
Wyman 36A
04-25-2007 18:38:04
Worked all evening trying to start my 36 A. Any have any tips on where to position the flywheel before trying to start. Man my shoulders are soar. Gettin Gas and spark.
CalJim
04-25-2007 22:29:41
 Re: Help Starting a 1936 A in reply to Wyman 36A, 04-25-2007 18:38:04
If you go to Robertscarbrepair.com then click
on "Technical Info". Look for something that
says "tractor will pull but won't idle". You
should get a diagram showing how to clean the
secret passage. CalJim
David Pearson
04-25-2007 19:10:34
Where exactly is the "secret" passage? I'm currently rebuilding a DLTX63 on my D
JD @ Antique Acres
04-25-2007 18:47:41
Have any blisters yet?.... been there done that.
Try bringing it up on the compression stroke on the flywheel side, if everything is up to snuff it should go with just a roll of the flywheel. I had a unstyled AR once, newly rebuilt had spark and gas but started hard. I went back into the carb and found that the secret idle passage was partially blocked cleaned it out and WOW... it started on the the second pull. Might be something to check.
Wyman 36A
04-25-2007 19:01:44
 Re: Help Starting a 1936 A in reply to JD @ Antique Acres, 04-25-2007 18:47:41
Thanks for the reply. This thing has not been started for over 10 years. The carburator was not on it when I bought it but was rebuilt over 10 years ago. Guess I need to open it up and take a look at it. Does any one know of any on line guide to rebuilding the Carb. or am I going to have to wait until I get my book? Thanks for all the help.
