420,430 etc hydraulics
Hayfarmer
04-25-2007 07:29:32
Has anyone been successful adding capacity to the hydraulic system on one of these? I have a loader with hydraulic bucket and seems like I run out of oil. Have considered external reservoir but think it would have to be at level of on board one or would cause leaks(more leaks)
Henry M
04-25-2007 17:40:29
 Re: 420,430 etc hydraulics in reply to Hayfarmer, 04-25-2007 07:29:32
hayfarmer
I got a #35 loader on a 420 and it does not run out of oil, even if you lift the loader bucket all the way up. It did take several cycles thru the full up motion to get all the air purged out of the loader cyls. I just kept working the loader, letting the foam settle in the tom and topping it off with oil.
Now since I am thinking about it, if all the air is out and the bucket is raised, there has to be an equal amount of oil return to the tom reservoir as you add on the back side of the cyls, since they are double acting.
It works for me. You got the valve rigged so it is an open center and will put oil on either side of the cyl depending on which way you move the valve handle off center?
