Deere M Rear Axle Seals
sschevrolet65
04-25-2007 05:03:05
Hello-
I recently ordered a new set of rear axle seals for my '49 M. The original seal part number is AM268T, about one inch wide with a rubber inner seal and a felt outer seal. The JD parts counter said that seal AT48334 replaced the old seal but it is only about 3/8" wide with a thinner rubber seal only - no felt. He also told me that there is no felt seal any longer. Is he correct or is there still a felt seal available?
I just wanted to make sure this is correct before I start assembling the tractor again.
Thanks in advance,
Matt
NJ
Henry M
04-25-2007 17:45:08
 Re: Deere M Rear Axle Seals in reply to sschevrolet65, 04-25-2007 05:03:05
I found out that I could not get the felt type for the 420 and the regular substitute with just the seal lips has worked fine for 5 years.
