JD 4010 update
newfarmer
04-24-2007 19:03:57
I popsted the other day asking how big a disc my 4010 would handle. well i hooked it up to a JD 12'2" rockdisc(heavy) about 5 inches deep. in third gear tracor just wanted to spin. In fourth it went right along with hardly any touble but workd the tractor and spun a good bit. i did not have extra weight just fluid in tires. Tractor weighs about 8500 lbs with me on it. And then just before dark and on my last pass i tried 5th gear just to see if the tractor would stall. But to my suprise it just moved right along hardly spinning but worked tractor hard. and one point in clay ground tracto bogged down to about 1500 rpm but eventually caught up. Also there was a flame comin out of muffler about 4 inches high. Is that normal if workin tractor extremely hard. I believ 5th was a little much becasue tractor started to get hot. but i never ran out of power just traction all of the time. Will i have better traction on unplowed ground. Thanks
msb
04-24-2007 19:57:18
 Re: JD 4010 update in reply to newfarmer, 04-24-2007 19:03:57
A set of duals would make all the difference in the world in that situation. Sounds like you have a HOT 4010. Yes the flame in that situation is normal. 5th gear and about dark? The evening air is usually heavier and will give you a boost in horsepower. The concept never really caught on , but some adventuresome guys used to add water to their intake manifolds for a cheap boost in horsepower years ago on both gas and diesel tractors.
G/MAN
04-25-2007 07:53:41
 Re: JD 4010 update in reply to msb, 04-24-2007 19:57:18
A fuel cooler of some sort would be better yet. Deere has done testing involving fuel temp and ambient air temp and their effects on horsepower, and fuel temp affects horsepower considerably more than ambient air temperature. An 18-degree F drop in fuel temp at the pump inlet will raise horsepower by 3-4%. The effect of an 18-degree drop in ambient air temp on a naturally-aspirated diesel according to Deere tests? Less than 1% - .9%, as a matter of fact. On turboed engines they consider the increase to be negligible. I've experienced the "power increase" as it cools off towards evening and into the night when doing field work, and it's my opinion that it's due to the fuel cooling off. There's a reason so many newer tractors have fuel coolers.
