1020 /bush hog
daniel in sc
04-24-2007 16:28:46
on the load/depth control, which would work best with a bush hog, 'L'(load), 'D'(depth), or 'L/D'(load/depth). still trying to get the hang of everything.
daniel in sc
04-26-2007 14:49:59
 Re: 1020 /bush hog in reply to daniel in sc, 04-24-2007 16:28:46
i just want a setting that won"t allow the bush hog to "run aground" every time i go over a bump. i don"t really care about getting a perfectly level cut as this is in the field far behind our house. thanks for the advice.
Tx Jim
04-25-2007 04:03:57
 L or L/D for plowing only in reply to daniel in sc, 04-24-2007 16:28:46
Use the depth control setting for any implement except a plow as you should have better height control if every things is set correctly. Use load setting or the less sensitive L/D setting for plowing and I don't mean snow plowing. I have to contradict Nylon's statement as JD tractors don't exert down-pressure on 3pt at any setting. Tx Jim
Nylon
04-25-2007 23:08:31
 Re: L or L/D for plowing only in reply to Tx Jim, 04-25-2007 04:03:57
Daniel,
Take the advice of txjim. I seem to have my L's and L/D's and D's mixed up. When using a back blade or a brush/grass cutter I want the implement to glide over the contour of the ground surface most of the time. Occasionally on the back blade I want some rigidity to cut with it. To me a "float" setting is what I am looking for in general. The weight of the implement (load) floats over the terrain. A depth setting holds an implement (plow) at a specific depth. I am not sure if it is D or L/d setting that allows a plow to rise up a bit when it encounters heavy (rock) or moderate (tough soil) resistance. I know that deere settings do not place specific down pressure...I get sometime a bit forgetful on stating that as the 460 farmall we have has a cylinder driven fast hitch that you can change a rear tire by putting down force on the backblade and blocking the frame.
Anyway, I should have said that the other settings wont allow an implement to rise in height as much as a simple gravity float setting. The resistance to rise forces implement to remain in stronger contact with the earth without technically using down pressure. I have found that backblading on deere with anything other than a gravity setting is pretty tough to control. My 1/2 mile driveway has alot of undulations, hills and curves and having the blade cut too hard can be a problem.
As for cutting with a brush cutter I do that on a 790 compact 4x4 and it only has a gravity setting. So it may be that a l/d setting on bigger deere's keep the cutter in contact with ground surface when going over a hump better than having it lift off like it does in a gravity setting. I would be afraid of it holding a cutter down too hard to the ground and tearing it up.....but that depends on the sensitivity of that 3 point. From what I have experienced on the 4020 and a back blade I would be hesitant to have the 4020 maul the cutter by holding it down too hard but I may be wrong on that assumption. TXJim could you shed some light on this for me as well?
John
Tx Jim
04-26-2007 04:08:31
 Re: L or L/D for plowing only in reply to Nylon, 04-25-2007 23:08:31
Nylon,with no implement on 3pt and with engine running,the 3pt arms can be raised up by hand in any and all L/D settings therefore I say JD tractors have no down-pressure on 3pt hitch just the weight of the implement attached. All settings are gravity. Load control mechanism senses the pull or flexing on load control shaft causing 3pt to raise slightly till flexing(bending) stops then 3pt lowers to original depth. Tx Jim
Nylon
04-26-2007 22:31:17
 Re: L or L/D for plowing only in reply to Tx Jim, 04-26-2007 04:08:31
Thx for the info txjim. I was under impression that one setting would keep the drag links from rising. Essentially holding them steady in one position even if tractor rear wheels went into a dip the implement would be forced into the ground. So my dilusional world is now dispelled :] I even pulled out my operators manual last night at 1 am to try and figure it out. I again after reading it thought that depth control meant that not only would it raise an implement it would also force it down in certain instances. So it is interesting to know that in any setting you can lift the drag links. So therefore every setting is a gravity setting. Thx for the info again txjim
John
Nylon
04-24-2007 22:10:25
Use the load setting...ie gravity setting. Implement will rise and fall with ground surface. Depth will force down pressure on implement as the tractor pitches forward and back on dips and hills. And l/d is a compromise between gravity and down pressure/ rigidity. That setting is used in things like plowing to keep plow at depth.
