D Flywheel
Randy Losey
04-24-2007 12:07:52
I am getting ready to pull the flywheel off of my 49 styled d to see about a oil leak coming from down behind lower rear area of flywheel.
Any help or suggestions on removing, repair and replacement will be greatly appreciated.
Glen in TX
04-24-2007 12:44:09
 Re: D Flywheel in reply to Randy Losey, 04-24-2007 12:07:52
Watch for the set screw in crank and tall spline when putting flywheel back on so it"s aligned right with crank. Also if the slinger spacer square notch is worn for square head dowel pin rebuild it or replace it and square head pin. The cover has to come off and there is a cork seal on back side of slinger spacer that you are looking to replace.
Paul from MI
04-24-2007 12:19:40
It's a pretty straightforward job. Loosen the clamp bolts and slide it off. You may need to wedge it the slot to free it up sao it will slide. BE CAREFUL!! That sucker is heavy. The rotating mass on a D is over 400#, flywheel is a big part of it. I put a good heavy C-clamp over the rim of the flywheel and cable to a come along or hoist to support it. A friend dropped the flywheel off his A on his foot--was off work for months and several surgeries later still has problems. Be sure to center the bearing housing around the crankshaft when you put it together and set the crankshaft end play at .010-.015". Use new grade 5 or 8 bolts when you re-install. Good luck,
Paul
