JD 2640 throwout bearing
BuckB34
04-24-2007 10:15:12
I hear a slight, dull knocking in my JD 2640 when I let out the clutch. Could it be the throwout bearing? If it is, I am debating whether I should take it in or try to split it myself if that is what it takes. Have never done that before. Any advice?
Mike M
04-24-2007 11:33:12
 Re: JD 2640 throwout bearing in reply to BuckB34, 04-24-2007 10:15:12
Another thing, with the engine off try to wiggle the fan blade/water pump shaft any play here and the water pump may need a new bearing. I had one once that the water pump knock traveled back through the tractor and you would of swore it had more major problems. I'm just glad I checked it first.
Mike M
04-24-2007 11:30:02
Pop off one of those little round tin covers on the LH side of the clutch housing. You should be able to see if it does have free play and some of those even have grease fittings on the throw out bearing,if so grease it up and retry.
Bob
04-24-2007 10:43:52
Do you hear the noise when your foot is off of the clutch pedal?
If so, the throwout bearing should NOT be turning, if the clutch has the required free travel.
Or, are you hearing the noise WHILE the clutch pedal is depressed?
