John Deere B brakes
David
01-08-2000 18:23:53
I have a 1936 model "B" and I need to relign the break shoes.I'm having a problem finding a tool to set the old style rivets that John Deere sends with the new bands.
Any suggestions on where to find a tool or some other way ?
HMan
01-08-2000 19:26:08
 Re: John Deere B brakes in reply to David, 01-08-2000 18:23:53
I did similar to Clooney exeptI put a steel dowel pin in a block of stell, leaving it sticking out about 3/8". I too used a transfer punch but I put mine in to lathe and contoured it. It sets them as good as factory.
.......block of steel.
01-08-2000 19:39:15
 Re: Re: John Deere B brakes in reply to HMan, 01-08-2000 19:26:08
I need to proof read!
CLOONEY
01-08-2000 18:38:29
David, the easiest way is to take them to a brake shop.-- I reline my own using a 5/16 rod in my bench vise that sticks up from top of vise about 1/2". Then set shoe with rivet on top of rod.I use a 5/16" transfer punch (not center punch) to set the rivets. Set them all loose until they are all in, then go back & set them all tight. It works quite well.
