1936 JD A Fuel Tanks
Wyman 36A
04-23-2007 17:25:37
Just brought home a 1936 John Deere A
SN 440377.
I am anxious to start the restoration have orderedsome books ans hope to try to start it this weekend. The Tractor has a small gas tank on the end of the large tank. Is this a dual fuel tractor. Does it start on gas and switch to Kerosene. Any information would be greatly appreciated.
Wyman 36A
04-24-2007 14:16:15
 Re: 1936 JD A Fuel Tanks in reply to Wyman 36A, 04-23-2007 17:25:37
Thank you for the replies. Could you guys tell me the correct starting proceedures. Thank you
Wyman
Ravgardner
04-24-2007 06:28:40
For starters don't try running kerosene. Burn regular gas. Most of the duel fuel tractors are run on gas only. Sometimes an operator will try it for giggles. Others that work them hard use kerosene. This is because there are several tricks to getting them to run on Kerosene and some very important procedures for shutting them off after running on kerosene. They must be turned from kerosene to gasoline while still running, then shut off. With kerosene in the engine it will not start till gas is put in its place.
Peavy Tx
04-23-2007 19:23:34
You are correct. I have a 38 B with same tanks and run regular gas in each tank useing the small one for a reserve. It has come in handy twice. Peavy Tx
