4020 fuel [diesel ]
rick in pa
04-23-2007 16:09:35
have a 4020 ran fine till one cold day in febuary seemed like fuel jelled or something started missing but kept running. got it out yesterday nice warm day. started missing and omiting white smoke. changed both fuel filters, bled everything even lines at injectors. now it will start up and run for a few seconds and shut off. but will start right back up and shut off in a few seconds again. could it be the fuel pump?
rick in pa
04-23-2007 17:51:29
 Re: 4020 fuel [diesel ] in reply to rick in pa, 04-23-2007 16:09:35
BOB Do you mean the line returning back to the injection pump from the top of the injectors?
jdemaris
04-23-2007 19:00:18
 Re: 4020 fuel [diesel ] in reply to rick in pa, 04-23-2007 17:51:29
It's not the line itself - it's the fitting screwed into the pump that the return line is hooked too. The fitting serves two functions - one as a pump housing pressure regulator and also has a one-way fuel check valve to prevent pump drainback. Main thing is - is has little ball and spring with a very small passage for fuel to travel. Your injection pump has an internal piece of plastic that tends to fall apart. When it does, it plugs the fitting. Unplugging the fitting is only a temporary measure and at sometime - the pump needs to be fixed.
Bob
04-23-2007 16:44:33
Rick,
The pump's housing pressure regulating valve/return fitting is probably clogged with chunks of the governor damper ring the guy in the post below is trying to talk himself out of replacing!
rick in pa
04-25-2007 18:56:40
 Re: 4020 fuel [diesel ] in reply to Bob, 04-23-2007 16:44:33
took the fitting out of pump and it was clogged, starts and runs ok. my concern now is small flakes of medal behind fitting and clogged in fitting, is this from the govenor damper ring? If so what should my next step be
