4430 3-point lift height
Meatcutter
04-23-2007 14:48:31
I have a 4430. With the load control in "Zero" position, the 3-point will raise to a certain height. With the load control in "Max" position, the 3-point with raise about six to eight inches higher. Is this normal or do I need to make adjustments?
msb
04-23-2007 19:16:30
 Re: 4430 3-point lift height in reply to Meatcutter, 04-23-2007 14:48:31
Set the L&D in the center hole.Lower the rockshaft and let it set for a few seconds. Then very slowly move the lever rearward until the lift arms just begin to move. Note on the scale on top of the console where the back(always the back edge) edge of the lever was when the arms(rockshaft) began to move. Then raise the rockshaft up as high as it will go. Let it set and then slowly move the lever rearward until the arms just begin to drop. Once again take notice of where the rear edge of the lever was at that point.Ideally the arms should begin to raise at 4 and drop at 1.
Didn't raise at 4 did it? Remove the bung hole plug at the rear of the tractor just to the right of the centerline and a few inches above the P T O. It should take an Allen wrench or a 1/2" extension bar the remove the plug. You can tape a 9/16" socket to a long extension bar to make the adjustment, but I STRONGLY urge you to weld the socket to a rod about 15" long with a 2-3" ell bent on the end. Drop that socket down inside and you got BIG trouble in River City. Anyway--with the tractor running and the lever set with the rear edge set on 4, reach in and engage the castle nut with the socket(firmly welded).Use a flashlight and have a peek inside to see the nut in question so you will have a good idea as to what you are doing. Then push the nut in to release the roll pin that keeps the nut in place.Now slowly turn that specially crafted wrench counterclockwise until the arms just begin to raise.Then lock the nut back in place. You might have to turn it very slightly for the roll pin to drop in the nut slot. Now go back to the driver's seat and check the set points. Most tractors will adjust to 4 and 1. On a few occasions I have seen some set a little tighter(thats good) sensitivity wise and you can set them at 3-1/2& 1-1/2 BE CAREFUL ! When that rockshaft begins to move--well--- just be out of the way. Its also a good idea for a novice to remove any quick coupler. I hope this is clearer than I think it is.bob
