axle
kendak
04-23-2007 10:56:57
Would like to put newer [more splines] axles in a 37 model "A" does anyone know what years will fit ??? Would 60 model axles work ?? machine shop work would be no problem...thanks ..Kent
ram ranch
04-23-2007 14:06:33
 Re: axle in reply to kendak, 04-23-2007 10:56:57
you can put 15 splined axles in, you have to change the bull gears also.I done it on a 36 so I wouldn't think a 37 would be much different.
Jason Mills
04-23-2007 12:38:22
I know that you can put the twelve spline axles into the 37 that had a 10 spline because I changed mine to be able to use the factory flat spokes that were on the 38 that had a bad trans. Easiest way to tell may be to check bearings numbers from tractor to tractor along with bull gear part number to see if they interchange. If the bearings and bullgear swap, than so will the axles. Good luck with youyr project, Jason.
