2520 Steering
Ferd
04-22-2007 16:27:15
My 2520 requires some effort to turn to the right. It doesn't take that much, but is definately different than turning left. Any idea what the cause might be?
It also has a very small leak in the steering motor (below the fuel tank). The shop manual shows an oil seal just above the spindle retainer. Can the oil seal be repalced without removing the steering motor?
Any help would be appreciated.
msb
04-22-2007 20:32:55
 Re: 2520 Steering in reply to Ferd, 04-22-2007 16:27:15
Yes, the seal can be replaced without pulling the motor, but that doesn't explain the hard steering. I would suspect the steering motor pistons need to bave the o-rings replaced. One or more of the o-rings are most likely leaking so much oil that the drain can't keep up with the leaking o-ring and has possibly blown the drain hose. You will have to remove one engine side rail and drop the pinion out the bottom so the pistons will come out. Biggest part of the job is supporting the engine with the side rail off. Its best to make a short rail out of a channel iron.Then you can support the engine safely with a splitting stand.Pistons and pinion have to be timed on reassembly. BE CAREFUL ! Don't be a gotta go,gotta go Joe.
