3010D fuel getting in oil pan
Eddie Jones
04-22-2007 13:21:42
What causes fuel to get in oil pan. I also notice oil coming out around bell housing, amd around RPM cable below injecter pump and also out from vent hole on dip stick cap. Thanks, Eddie
m sb
04-22-2007 20:44:01
 Re: 3010D fuel getting in oil pan in reply to Eddie Jones, 04-22-2007 13:21:42
A word of caution that can save you some possible heartache. If you pull the pump shaft out of the pump, wire the throttle lever in the wide open position-FIRST . This will keep the governor weights and thrust washer from falling out of place. I always use a large old o-ring to hold the lever in place.
And don't use the tractor in this condition. There is a good chance you can spin a main bearing or a rod bearing. Its usuall the mains that go first and then you are looking at an expensive line bore job plus an overhaul.
Brent Weaver
04-22-2007 15:14:40
GeraldJ is right on the money I would start there first, it's the cheapest. Then move on to the injector pump. Brent
Glen in TX
04-22-2007 17:34:34
 Re: 3010D fuel getting in oil pan in reply to Brent Weaver, 04-22-2007 15:14:40
May take more time and labor but the 2 little rubber lip seals and a set of injector line washers cost less than a lift pump from JD. Just taking me a while to get woke up today after being out on more grass fires all night.
Glen in TX
04-22-2007 13:30:58
I hope you aren't running it like that because the fuel that leaked past pump seals filled the pan pushing the oil out you see! Running like that long will ruin the bearings and engine in short order so get it fixed now and don't run it anymore. Pull the injector pump off and put new seals on the shaft and check bushing bore in pump for wear. If bushing is worn take it to a pump shop for replacement. The seals were just discussed in another post recently and some people have to have the little compressor tool for the pump seals but most times you can lube the seals with diesel fuel or grease and twist and turn the pump on and slide it right on seals carefully. If you invert the seal lips it will still leak but you should be able to tell sliding it on if they inverted it won't slide on easy. I&T shop manual, JD tech publications for manuals, http://techpubs.deere.com
Gerald J.
04-22-2007 14:08:16
 Re: 3010D fuel getting in oil pan in reply to Glen in TX, 04-22-2007 13:30:58
Don't neglect the lift pump. It is easily worn out too and a split in the diaphragm will run fuel direct to the crankcase.
Gerald J.
Eddie Jones
04-22-2007 16:28:19
 Re: 3010D fuel getting in oil pan in reply to Gerald J., 04-22-2007 14:08:16
Gerald J. "Lift Pump" Is that the fuel pump? Thanks Eddie
Gerald J.
04-22-2007 19:06:18
 Re: 3010D fuel getting in oil pan in reply to Eddie Jones, 04-22-2007 16:28:19
Yup. I know the one on my gas 4020 failed a couple years ago, just quit pumping and I think it was putting some gas into the oil too.
Gerald J.
Glen in TX
04-22-2007 17:26:21
Yes, check it too. It looks just like a automotive fuel pump on side of engine with line coming from tank and other line running across other side to injector pump. There is a shut off valve up under tank to turn off when changing pump. I was talking about the 2 lip seals on injector pump the lines run from to injector.
