4320 J.D.
Ron in N.E. Col
04-22-2007 07:53:31
I am having trouble with a 4320 JD tractor. It has a loader on it and every once in a while, the hydraulics will just quit. If I let it sit for a few hours, then it works fine. Could this be a high pressure leak inside the case? I have cleaned the screen in the sump and it only has about 100 hours on a new hydraulic pump. Anyone have any ideas? Thanks
Ron in N.E. Colo
04-23-2007 08:37:55
 Re: 4320 J.D. in reply to Ron in N.E. Colo, 04-22-2007 07:53:31
I finally got to talk to an old friend who is a retired JD mechanic. He thinks that the supply line coming from the transmission sump and going to the transmission pump has a crack in it. he said this occassionally happens. As the oil and transmission get warm, the crack opens up, and as I use the clutch more, it finally loses its prime. We will tear it down later this week and find out. Thanks to all who helped! I will let you know what we find.
Ron in N.E. Colo
04-23-2007 05:36:28
I am losing all hydraulic function including steering. The main pump was replaced because the old pump failed. The main shaft seal failed, and was pouring out oil. It was about the same money to put in a new pump as a rebuild job. I was trying to insure that I would have less trouble with a new pump. It seems as though it somehow loses its prime to the main hydraulic pump. I did not have this trouble until I had new pump installed. If the transmission pump becomes weak, will it not prime the system? This would make more sense as to why it resumes when cold. By the way, the filters look good when changed, no flakes or anything. I have also completely draind and changed to new John Deere fluid. Thanks
Mike w J
04-22-2007 11:37:37
I have a 4640 that sometimes not very often will do that most of the time if I shut it off and wait just a minute it will come back when I start it. But not aways the problem with mine is the front pump will destroke . Twice I have had to take the stroke control valve out of the front pump and put it back in . I was told by the dealer where I bought the tractor new in 1983 It only takes a little flake to stick the valve . mine has done this about 5 or 6 times since new . 8000 hours and I haven't had to take the pump off yet.
G/MAN
04-22-2007 11:41:38
 Re: 4320 J.D. in reply to Mike w J, 04-22-2007 11:37:37
Yes, the stroke-control valve sticking is pretty common. You're lucky if it will usually free itself. Most I've worked on have been stuck tight. What has me thinking oil starvation of the main pump for some reason rather than a stuck stroke-control valve is that he mentions that the pump seems to be cavitating. Were in the stroke-control valve, I'd expect the pump to be more or less dead in the water, and it shouldn't cavitate because it shouldn't really be in stroke at all. You never know, though. Could be any one or more of a number of things.
msb
04-22-2007 09:58:45
Just on an outside chance the tractor was once set up for a single acting cylinder, remove the long nut on the valve behind the hydraulic filter and see if the screw is turned all the way in.
Ron in N.E. Colo
04-22-2007 08:41:30
Sometimes it does it when I have the clutch in, and sometimes not.I can put it in neutral and it will not resume hydraulic function. It seems as though it begins to starve for oil and will not prime until it cools.Is there a valve on the inflow side of the pump?
G/MAN
04-22-2007 11:27:02
 Re: 4320 J.D. in reply to Ron in N.E. Colo, 04-22-2007 08:41:30
What hydraulic functions are you losing? Steering, hitch, brakes, SCV or all of the above? It's possible that there's an internal leak that's some of the oil from the transmission pump to not make it to the main pump, and once the auxiliary reservoir up front is drained of oil the main pump is starving for oil. Or the tranny pump itself is very weak and is simple not moving enough oil. Different functions and applications take different amounts of hydraulic oil. Why was the main pump replaced, and was this problem happening before it was replaced?
wilamayb
04-22-2007 08:06:52
Ron, I'm going to tell you a few things that you may already know, so dont take it as insult. Your 4320's supply pump is being driven only while your drive clutch is coupled with the flywheel. This being said do you seem to have this problem while the clutch is depressed for long periods of time? If so next time you have this episode put the tractor in neutral and let is sit running with the clutch out to see if you regain hydraulic function.
If you already know all this lets go farther. Suspect problems in the supply circuit to the main pump. Here are a few things to investigate.
1. leak before the supply pump
2. blockage to supply pump
3. insuficient flow from supply pump
One last thought. Do you ever cavitation before the pump quits or is it just like cutting it off?
Give us a few more hints so maybe we can save you some time in your search.
