4020 conversion
Chuck H. WI.
04-21-2007 21:19:52
I have a 24 volt 4020. Gen. needs rebuilding, How do I test the starter for too much draw. I if starter is bad should I convert it to 12 volt system. I want to keep it as original as possible, will converting hurt its value. Also, For restoring it has 18.4x38"s, wheels are actually 34"s. It just has bigger spacers. Should I go back to 34"s or stay with 38"s. Thanks for your input. It"s much appreciated. Chuck
Gerald J.
04-22-2007 06:33:59
 Re: 4020 conversion in reply to Chuck H. WI., 04-21-2007 21:19:52
12 volt conversions with the NipponDenso starter seem to work well. Going to an alternator helps a great deal because the generator only puts out 10 amps, and you can consume most of that in the lights making it take half a day or longer to charge the batteries from one start. When used as a short time run utility tractor it won't keep up. There is a Deere kit for the complete conversion.
There was a 24 alternator used for 4020 with cabs. I've not noticed one in the field, but it is in the early 4020 parts book.
The 4020 could have 13.6 through 16.5 x 38 as factory tires, or 18.4-34 or 23.1-30 or something like that. I don't have my 4020 manual at the computer. The 13.6 were supposed to be run only as duals. My 4020 has 12.4-42 for spraying. I made the wheel adapters. Yours uses tall wedges probably from M&W, not a rare conversion. Gets you more ground clearance. I have 11.00-16 on wide rims on the front also, keeps the front end from sinking in soft soil or with loader loads.
My gas 4020 has an alternator and an ammeter (its not restored, its a working tractor) and I won't go back to a generator for real world use. The 20 amp generator didn't charge to keep up costing a new (expensive) battery each year. With a smaller side terminal battery and an alternator it works far more reliably. I started it Wednesday for the first time since I used it to spray the bean crop in the middle of last summer. It started just fine as if it hadn't sat for 8 months.
Gerald J.
