G/MAN
04-22-2007 11:11:55
Re: 4030 engine in reply to jeff outwest, 04-21-2007 18:47:05
I think if you start doing the math, you're going to find that doing an in-frame overhaul on the existing engine is going to be at least as fast or faster than replacing the entire unit. To replace the engine, the tractor will have to be split - meaning that many hydraulic lines, A/C lines and heater hoses, wiring harnesses, etc. will have to be unhooked so the tractor can be split and the engine slid out of the rear of the frame rails. The clutch and flywheel will have to be removed from the existing engine and installed on the new one, and the clutch will have to be properly adjusted. The hydraulic pump coupler will have to be unhooked as well, etc. And the new long-block probably won't come with any fuel-system components - they will have to be transferred to the new engine from the old as well. And this is all contingent on you having splitting stands and an overhead hoist capable of handling the engine, etc. Labor-wise, it may just be a wash - an in-frame vs. replacement probably comes out about the same. Cost-wise, I'll bet you're going to dump substantially more in a rebuilt engine. If your old engine is simply worn-out, a simple in-frame and head rebuild should restore good performance. Deere pushes their RemanSelect engines pretty hard, but in nearly every case we come across where the engine is simply tired and hasn't catastrophically failed, an in-frame overhaul is so much cheaper than replacing the engine that it isn't even funny. Try around $14,000 for a Deere RemanSelect engine for a 4850 alone - that's not figuring in labor to R&R, vs. around $7000 parts and labor for a good in-frame overhaul. I know you're not dealing with a 4850, but that will give you some idea of what you may be dealing with.
