Boling Machine 4020 Load Control Shaft Bushings/Se
MRN
04-21-2007 10:42:22
Since it's Saturday and Boling Machine isn't open - I'm hoping that someone here can answer my question so I can get this job wrapped up this weekend.
I ordered and received a replacement load control shaft and bushings for my early ser. number 4020. When I attempted to install the bushings I noticed that they are considerably larger than the originals, but do fit into the rear housing. I now have one of them in the housing, but it is not seated as far in as I thought maybe it ought to go. And although it is flush with the outside of the rear housing and will not budge another nanometer (its as far in as its gonna get). This leaves no room for the dealer provided seals (the rubber ones that are green and black). The bushing installation instructions don't address a change of bushing size or exactly how the new bushing should fit. So now I'm wondering if I was sent the wrong bushings or are they correct and simply are designed larger and thus fit differently replacing the other rubber and metal type seals.
RFox
04-24-2007 19:05:12
 Re: Boling Machine 4020 Load Control Shaft Bushing in reply to MRN, 04-21-2007 10:42:22
I did some on a 4010 last summer, all the parts fit right in just like OEM. I'd venture to guess they gave you the wrong bushings unfortunately..
