Hi, you old D men
HaroldIHC
04-20-2007 21:14:24
I am instaling a crankshaft and new bearings into a 1929 D. I dont know if I lost the right hand main bearing adjusting screw or if it fell out causing both #2 rod and right main to burn out. I would like to know if that is a special bolt or could I just make one from a bolt that would work? Also does it have a set screw like the left main adjusting screw? Any information would be very helpful. Thank you.-----Harold
Glen in TX
04-20-2007 21:47:52
 Re: Hi, you old D men in reply to HaroldIHC, 04-20-2007 21:14:24
First of all I can tell you never got yourself a parts catalog yet Harold. It doesn't tell the length, thread size, or show 2 illustrations in D PC658 parts catalog but does show a different number for the set screw for RH main bearing as D174R vs. D175R for LH main bearing so must have been some difference in it. Just get a set screw of proper thread size and you should be able to figure out the length and then grind or turn threads off some on end that meets bearing holder half rounding pointed end off some and should work. Replace the felt in RH bearing holder too and most important make sure the hole in bearing shell aligns with oil hole in bearing holder. JD was selling again the early D, GP tractor & E engines service manual SMF116 but heard they were out of them again recently.
HaroldIHC
04-21-2007 08:33:01
 Re: Hi, you old D men in reply to Glen in TX, 04-20-2007 21:47:52
Thanks much Glen, I did get myself a parts catalog and a service manual as per your advice. The service manual is very vauge on that subject. The parts manual shows two different bolts which I allready know but it does not show jamb nuts which the left bearing has. The problem is the right screw is about three inches shorter and has very little room for a jamb nut. What would work is a 7\8" allen screw, but where to get that. I will probably have to hunt the bone yards. I got nos bearings from an old farmer not 15 miles from me,Thanks to this page. I am still open for more advice.Thanks --Harold
Glen in TX
04-21-2007 08:55:01
 Re: Hi, you old D men in reply to HaroldIHC, 04-21-2007 08:33:01
Yes, Harold you are right I don't see a jamb listed either but do remember there was one on LH bearing set screw and would have something on both to lock them. I read service manual again last night too and it doesn't tell much like you would hope for. So the RH set screw just fell out not to be found? Don't have a early D right here anymore so can't go look and been too long to remember that on a 28 we took broke crank out of putting one in from a 30 model. It's a wonder the crank didn't break on yours when main came loose. Most machine shops would have set screws or jamb nuts or a local fastener bolt place. If not check with McMaster Carr.
