1010 hyd pump
Mike Moyer
04-20-2007 07:53:38
Hello to all, I was wondering if anyone knows if there is a hyd pump in the back half of a 1010 or does the 3 point hitch work off of the one at the base of the steering support? Any info would be greatly appreciated and thank you. Mike
Mike moyer
04-20-2007 09:48:55
 Re: 1010 hyd pump in reply to Mike Moyer, 04-20-2007 07:53:38
that helped a lot. Thank you.
Bob
04-20-2007 08:20:03
There's only one hydraulic pump. The pump on units equipped with power steering has a flow divider built in.
Mike Moyer
04-20-2007 08:23:06
 Re: 1010 hyd pump in reply to Bob, 04-20-2007 08:20:03
ok, where is that pump located? Thank you for responding.
Bob
04-20-2007 09:06:24
 Re: 1010 hyd pump in reply to Mike Moyer, 04-20-2007 08:23:06
third party image
The pump sits on top of the tractor center section in place of the cover, Key # 12, which is used on tractors WITHOUT hydraulics.
