DLTX CARB rust problem
NE IA Dave
04-19-2007 21:06:05
I got a DLTX carb this evening that I totaly cleaned / rebuilt probably five yers ago. It is actualy fun to tear one down that hasn't rusted for fifty years. The drill plugs almost jumped out on their own even.
The problem is it was full of rust, (bowl / stem). Prior to blasting I got probably three tablespoons full of rust. It made me sick to see this as I know that no carb has ever left my shop with so much as a speck of rust inside or out.
I do remember Roberts had a chemical treatment that did not work, so they have discontinued it. So I was wondering what could be done?
Sorry the guys mother in law dropped it off, and had no information. There was silica sand from a blaster I assume in the screen area. The tractor ran like a million dollars if I remember correctly after original rebuild. The nozzle had more than a little resistance to remove.
I drain the carb on any DLTX every time I let them set for a week or more, and probably almost ever evening that I run the tractor.
I'm sorry that I have no idea at this time if the tractor has sat for the last four or five years with gas in it and not being run, or I guess any information. I should have called the guy, then posted, but it was past his bed time. I won't be able to sleep tonight wondering how to avoid this problem. I figure a pump oil can and screwing the drain cock open and filling her full of oil if it was to sit for anything over a year. Might help? I know that a cast iron frying pan has to be seasoned, but gas would scrub that idea inside a carb.
Thanks in advance.
P Browning
04-20-2007 06:20:58
 Re: DLTX CARB rust problem in reply to NE IA Dave, 04-19-2007 21:06:05
NE IA Dave -- While the following article (Below my sign-off) does not address the rust question you asked, it would have prevented the problem!
As for your basic question, the carburetor body is iron -- and a treatment with a phosphoric acid compound (a rust converter) will afford some degree of rust prevention. (PatB) ----- ----- ---
PREVENTION!
Operating TIP - Varnish Build-Up -- As the fuel evaporates from the float bowl, it leaves sediment, residue, and varnishes behind, which clog the passages and can interfere with the float operations. This is particularly a problem in antique tractors operated for only a part of the year and left to stand with full float chambers for months at a time. Commercial "fuel stabilizer" additives are available to reduce this problem, albeit with limits to its success!
One of the very best combination of ways to combat varnishing residue build up in tractors that do nothing for long periods of time is remove the regular gasoline from both of the tanks and from the carburetor. Then install a quart of kerosene (or diesel) putting 3/4 of the kerosene into the fuel tank and the remainder into the smaller gasoline tank. Open the fuel valves so as to flow of the kerosene down into the carburetor, then close all fuel valves. During subsequent startup, simply open the fuel valves and allow all the kerosene to flow out of the system, add gasoline, and start your tractor. All-fuel tractors were designed for these methods, and performed well over the years; more often than not, as the farmer's only tractor!
dds-inc
04-19-2007 21:58:16
if you totally rebuilt the carb 5 years ago and hes been keeping the tractor in the dry, i would assume he's got rust in the fuel tank. The only way to get rid of that is to clean and coat the tank.
If he's been running the tractor a lot in the past 5 years, believe me, a lot of tiny rust will bypass that sediment screen adn settle in the carb instead.
