GP R2 Magnito Installation or Setup
Ronny Maxwell
04-19-2007 19:29:43
I own a 1930 JD "GP" with a Wico magnito currently installed on it. I've just purchased a Fairbanks Morse R2 magnito. What do I need to do to install and set it up properly? Any help or advise would be greatly appreciated.
Glen in TX
04-20-2007 22:07:12
 Re: GP R2 Magnito Installation or Setup in reply to Ronny Maxwell, 04-19-2007 19:29:43
Ronny, I don't have GP operators manual but the JD SMF116 Service Manual for JD Tractors & Engines (covers early D, GP, tractors & E engines). It says the rear terminal on mag goes to LH cylinder (flywheel side) and front wire goes to RH cylinder on the GP. On Ds and other tractors with mags like the Splitdorf & Wico the front or top terminal on mag goes to LH cylinder.
Glen in TX
04-20-2007 12:35:03
Thinking you use the front terminal on mag wired to LH #1 cylinder on flywheel side. Otherwise time and mount it like you would any other on a JD 2 cylinder. You will need a phenolic float drive coupler between engine and mag or can make your own from UHMW plastic. JD Publications should have copies of GP operators manual that will have timing instructions and other things you'll need to know to take care of that GP. JD publications 800-522-7448. Following are timing instruction for early D with base mount mag but GP will be similar unless the retard on mag works backwards from what I'm remembering.
Magneto Timing D early unstyled 24-30 :
Timing mag for D #30400-109943: 1. Have the mag secure to engine mounting and need 1/32" clearance between mag drive and float coupling. 2. Loosen the 2 clamps on mag engine drive flange allowing mag to turn freely. 3. Remove LH spark plug # 1 cylinder flywheel side. Turn engine forward in direction it runs to compression stroke on LH cylinder (flywheel side) with mark on flywheel "L.H. Ret. Spk." in line with the arrow or mark on cover at 3 o�clock position.
4. Remove breaker cover and dist. cap on mag. 5. Set spark lever clear back (fully retarded spark). 6. Turn magneto same direction as flywheel runs until brass segment on distributor disc is in upper right hand corner and breaker points are just beginning to open. 7. Tighten 2 bolts on mag drive flange. 8. Spark plug wire from forward mag terminal goes to LH spark plug and rear one to RH spark plug. 9. Then check the impulse trip by turning flywheel back 1/2 turn and if mag has manual impulse trip you will have to set it to trip. Then rotate engine slowly forward and impulse should trip or click as mark on flywheel lines up with mark on cover at 3 o�clock position and LH spark plug should fire. If not loosen drive flange bolts and if trip is early turn magneto opposite direction engine runs. If late turn mag same direction as engine runs and recheck until you get mark to line up. If that doesn't get you in time then you could have mag impulse problems or need to time the camshaft properly. Good luck.
Ronny Maxwell
04-22-2007 03:56:05
 Re: GP R2 Magnito Installation or Setup in reply to Glen in TX, 04-20-2007 12:35:03
Thanks Glen for the help. I'll give it a try. The information is much appreciated.
