BIG 70 starter question
GTHING
04-19-2007 11:05:00
I have a 70 with 9 3/4 x 7 engine with compression releases.I have a 70 lp fresh overhaul starter and it spinning over slow.The main battery lead is small by changing the cable to heavy gauge cable and putting 2 batteries (currently 1 1000ca installed) together should this help my problem.I dont know if I can stuff a bigger starter in that hole not a lot of room in there.What are other guys using in BIG cube 70's?
buickanddeere
04-20-2007 15:00:15
 Re: BIG 70 starter question in reply to GTHING, 04-19-2007 11:05:00
Go beefy on both the cables. Don't connect the + to the battery box. Run the cable right down to the a body bolt on the starter or to the main crankcase. Power is BOTH amps and volts together. A 1000CCA 12V battery providing 500A will have a higher output voltage than a 500CCA battery providing 500A. In short, bigger is better.
GTHING
04-20-2007 05:31:19
Thanks everyone for the GREAT information. I guess I am going to the battery shop this weekend and have my cables made( double 00) along with picking up two new batteries. This should make it spin up so we can pull next weekend.
dds-inc
04-19-2007 20:26:37
running batteries in series does nothing for amperage. running them in PARALLEL does give it more amps.
simple electric rule, series = more volts, same amps. parallel = more amps, same volts
DSK
04-19-2007 17:59:37
I am running a simular 70 to yours. I am running 2 850CCA 12V in parallel with the stock starter & 2.0 gauge cables that are 60" long as the batteries are mounted on the front of the tractor. I installed petcocks in the Powerblock when I built the tractor but the tractor will always start without opening them but my c.r is only 8.6-1. If your starter is in shape it should get you cranking under any circumstances if you use the petcocks.
G/MAN
04-19-2007 17:46:50
Cranking power is all about amperage - the more the better and there's really no way to "overdo" it. Amperage is additive with multiple batteries wired in parallel, while the voltage stays constant. One of the easiest ways to greatly increase the cranking power on a tractor like a 4840 is to ditch the standard dual 6-volt batteries wired in series and install 2 12-volt batteries in parallel, and your 70 would benefit from adding another 12-volt battery the same way. Your "big" 70 may takes some CCAs to turn over, but stop and think about what it takes to spin a 466-cube 6-cylinder diesel with 15.5:1 compression with a piston coming up on compression 3 times per engine revolution, not too mention driving a hydraulic pump and a bunch of transmission components on a cold morning with cold oil and you start to get the picture. Use the biggest good-quality battery cable you can get routed from the batteries to the starter, and leave those POS bolt-on battery terminals on the parts-store shelf - use quality crimp-on or solder-on terminals or really get serious and run some solder INTO crimp-on terminals once they're crimped. Also make sure you have a good solid path to ground between the starter frame and the tractor frame and between the negative posts on the battery and the tractor frame. Knock the paint off and get down to bare metal where the ground cables meet the frame, and where the starter bolts up. A little di-electric grease between them won't hurt either.
teddy52food
04-20-2007 05:28:44
 Re: BIG 70 starter question in reply to G/MAN, 04-19-2007 17:46:50
You say Cranking power is about amperage. I tend to disagree. Why is it when you go from 6v to 12v the starter spins faster but the amp draw is less???
gtx1967jewison
04-21-2007 07:35:35
 Re: BIG 70 starter question in reply to teddy52food, 04-20-2007 05:28:44
you obviously have vertually NO UNDERSTANDING OF ELECTRICITY. learn OHMS LAW & you will see why/how amperage goes down when volts go up. yes amperage is what you want/need more of to turn a hard engine. you only have 12 volts available so amperage is all you have to work with anyhow.
G/MAN
04-20-2007 13:36:34
You can disagree all you like, it's common electrical system knowledge. You might try starting with the common formula of wattage being equal to amperate multiplied by voltage and figure out why the amp flow can decrease when voltage is increased. Voltage is essentially electrical "pressure", and amperage is electrical "flow". Why do you think a battery with 900 cca (cold cranking amps) will start an engine in the dead of winter more effectively than one with 500? And why is it that installing two twelves in parallel in place of 2 sixes in series, as in the 4840 example I mentioned, produces better cranking without increasing the voltage so much as one volt? As I said, anyone familiar with electrical systems knows the story.
Drew
04-19-2007 12:24:52
I have started a 6.75" x 9.375" A with a stock starter and it worked fine. That was with 2 1000cca batteries parallel. And like Mike said, get big cables!
Mike M
04-19-2007 12:11:02
The farther away the batteries from the starter the bigger the cables you will need ! Bigger cables should help,but you got alot of engine there too !
