Injection pump shaft removal
MH
04-19-2007 05:41:16
Trying to remove the injection pump shaft on my 1020D. Have the pump off & have not had any luck with removing the shaft following the IT manual method. Can anyone point me in the right direction. I'm a little timmid, don't want to damage anything.
Thanks, Matthew
third party image
msb
04-19-2007 16:57:26
 Re: Injection pump shaft removal in reply to MH, 04-19-2007 05:41:16
I know its easy to replace the cup seals on the shaft,but whatever you do, don't invert them.There was a service bulletin years & years ago warning against this(including pictures of the damage), inverting the seals causes microscopic tears in the inner part of the saels that cause premature seal failure. Liberally greasae the seals and use a o-ring tool to slowly work them on and into place without turning them over.
I rarely ever use the split seal clamp to reinstall the pump(only time I ever inverted a seal was when I used that tool).Once aqgain use gobs of grease on the seals. Slightly tip the pump down and start the first seal in at the bottom of the brass tube.(Pilot tube).Slowly twist the pump in a circular motion, making sure the seal goes into the tube until the seal completely disappears. Then keep wiggling the pump in a circular motion as you push it on the shaft. This will help walk the seals over any scoring in the tube(unless the tube is damaged very badly). Once the pump mounting bolts enter the pump base,simply push the pump in place.
I use this same proceedure when installing a shaft in a pump on the bench, except I wiggle the shaft.
jdemaris
04-19-2007 10:32:18
Not sure I understand exactly what you did. 1020 Deere came with two very different model pumps - a C series and a D series. With the C series - you have to remove the cover on the engine front timing cover, and then unbolt the pump drive and remove the entire pump in one piece. That is NOT the pump you have. Removing the entire pump only applies to the 1020s with CBC pumps. You've got a D series - either a DBG or a JDB. With your pump, the shaft stays on the engine and the pump slides off of it. In regard to the Roosamaster tool #13371 that is normally used to reinstall - depends what the word "need" means to you. Some people can't get the seals installed without it, some can't even WITH it, and some manage without any special tool. Depends on your skill level. It is very easy to flip a seal over backwards when installing and not notice it - until the crankcase fills with diesel fuel. Chance are - if your seals were leaking, the bronze bushing in the pump is NG. Usually it will have a ridge worn into it from the seals - and sliding it back over new seals is very difficult. You can buy a new bushing for $10 (technically called a "pilot tube).
MH
04-19-2007 12:02:10
 Re: Injection pump shaft removal in reply to jdemaris, 04-19-2007 10:32:18
The shaft is still on the tractor. I thought you needed the shaft out to renew the seals. I understand now & will leave the shaft where it is. Thanks, Matthew
MSM
04-19-2007 07:35:38
Why do you want to pull the shaft,is it bent or scored? Seals can be replaced with the shaft in place,just need the proper tool to hold the cups.
Bob
04-19-2007 08:45:42
 Re: Injection pump shaft removal in reply to MSM, 04-19-2007 07:35:38
HOW in the heck is he going to replace the shaft seals in that pump, with the shaft in place, in the pump????
And, you don't need special tools to "hold the cups", just a tappered plastic "thimble" to slide the cups over, on their way to the seal grooves in the shaft.
MSM
04-19-2007 09:11:22
 Re: Injection pump shaft removal in reply to Bob, 04-19-2007 08:45:42
The pump is removed,after aligning the timing marks, by sliding it off the shaft,and yes you need the tool to collapse the cups slightly so they don't roll over as you reinstall the pump.It can be done without the tool,but. it makes the job alot easier.
Bob
04-19-2007 08:49:55
 OR.... in reply to Bob, 04-19-2007 08:45:42
Has he pulled the pump off of the shaft, leaving the shaft in place in the engine, stcuk in the drive gear?
MH... If that's what you've done, be aware that the pump driveshaft will engage with the hydraulic head at two possitions, 180 degees apart. (The drive tang is NOT offset.)
If you get that wrong, you will be hopelessly "out of time".
MH
04-19-2007 08:41:44
No, shaft is fine, maybe I read the IT wrong. I would much rather replace the seals with the shaft on. I saw you need a special tool. I will give her a try. Thanks,
Matthew
