2010 john deere
wkk427
04-18-2007 20:33:30
i have a 2010 gas that has been setting up for a while and now will not crank i checked compression on all four cylinders and it was good after filing and cleaning points i have spark at each plug at the correct time i sprayed eether directly into throat of carb and it did not phase it i thought i might have a stopped up intake manifold but it sucks your hand in while cranking does anyone have any ideas
George in Georgia
04-19-2007 10:09:40
 Re: 2010 john deere in reply to wkk427, 04-18-2007 20:33:30
A comma now and then might help. :-) Seriously though spark, compression, correct timing, air and fuel all being in place you should have at least some sputtering or back firing.
Usually "spark" is the weakest link. If you really have a good fat blue spark at each plug, and the engine is correctly timed, that is the biggest thing out of the way.
Next is fuel. Maybe try putting some fresh gasoline in a small spray bottle and while the engine is cranking spray a bit directly into the carburetor (choke 'off') and see if it doesn't pop and sputter or even run as you keep spraying.
wkk427
04-24-2007 22:23:24
 Re: 2010 john deere in reply to George in Georgia, 04-19-2007 10:09:40
thanks for the info. I talked to a mechanic today and the only thing that he could think of was that it might not be turning fast enough to suck the gas up into the intake. i put a good hot battery on it and it fired right up.thanks a lot and i will try to do better with the.....and,,,,, ,,,
