DLTX 8 Carb help, please.
Loren in Iowa
04-18-2007 18:53:46
Having trouble making my 1941 A idle. It has a DLTX8 (early A) carb, and the tractor sat out in a cow yard, for several years. Was full of rust. Good friend, and experienced tractor mechanic rebuilt it for me. Both needles, and jets, were rusted, to the point that they needed to be replaced. Plugs were all removed, and passages cleaned, and blown out. Runs down the road good, but won't idle. You can close the idle screw all the way, or pull it out and hold it in your hand, and it runs the same. Tried a borrowed carb, and that works fine. Is there a hidden passage, full of rust, that we are missing, or some such other thing?
JD@Antique Acres
04-19-2007 08:51:11
 Re: DLTX 8 Carb help, please. in reply to Loren in Iowa, 04-18-2007 18:53:46
It's the secret passage in the carb stem. Being a BRASS carb you do not want to drill it to clean. Besides it won't be rust anyhow. Use a carb cleaner to desolve the gunk and then check to if the passage is clean.
Loren in Iowa
04-19-2007 10:23:34
 Re: DLTX 8 Carb help, please. in reply to JD@Antique Acres, 04-19-2007 08:51:11
How do I find this secret passage? Are there no plugs at the ends? Is there a picture of it, somewhere?
JD@Antique Acres
04-19-2007 11:36:49
 Re: DLTX 8 Carb help, please. in reply to Loren in Iowa, 04-19-2007 10:23:34
You will need to remove the upper brass plug in the carb stem. After it is removed push a wire in to see if it is plugged. You can measure the wire, it should go in nearly the thickness of the stem, hitting the opposite side of the stem wall. Again I would advise not using a drill bit on softer brass carbs.
Loren in Iowa
04-22-2007 07:34:54
 Re: DLTX 8 Carb help, please. in reply to JD@Antique Acres, 04-19-2007 11:36:49
JD-That did the trick! Runs pretty nice, now. Thanks a lot, for your help.-Loren
dds-inc
04-19-2007 21:52:31
how the heck does using a correct size drill bit by your fingertips hurt passages? When robert gives out these bits, he tells you to use your hands.
JD @ Antique Acres
04-20-2007 07:46:06
 Re: DLTX 8 Carb help, please. in reply to dds-inc, 04-19-2007 21:52:31
This is Robert's advice. Do not use the drills on brass carbs.
dds-inc
04-18-2007 20:16:18
experienced? i guess he isn't so "experienced" when he didn't bore out all the holes in the carb!
NE IA Dave
04-18-2007 19:34:52
Probaly also recheck the one that is just up from the pipe threads on the very bottom (stem)of the top 1/2. You should be able to measure your drill bit to see if you get clear through. Rust has fooled a lot of folks thinking they hit metal on the other side.
40 JD G
04-18-2007 19:30:20
There are numbered 6 inch drill bits sold by Roberts Carburetor Repair, that are needed to get all of the dirt and rust out of the idle passages. I always had problems getting a tractor to idle good, and then i bought those 2 drill bits. They work great, when you buy them they send you a paper on which ones to drill out.
bigblock
04-18-2007 19:02:30
there's another passage about 1/2 inch inboard of the idle screw holes.straight down just as the idle screws are(parallel).I had to clean mine with a bent torch tip cleaner.I didn't even know they were there until I sand papered the bores.
