4020 diesel fuel system
J. Brock
04-18-2007 16:52:56
From my search of the J.D. discussion page, it looks as if there could be several different types of fuel supply and filter systems for a 4020 model. I told my uncle I could change his fuel filter for him without really looking at it yet. I know it is a 1967 4020 diesel. Any hints on identifying what Ive got here before I go and make myself look like a fool and get a filter that isnt correct?
J Brock
04-20-2007 20:53:48
 Re: 4020 diesel fuel system in reply to J. Brock, 04-18-2007 16:52:56
Ithink it has the square one. Ill find out for sure in the morning. Thanks for the replies
jimtnv
04-18-2007 20:24:15
doomed. you'd be surprised how many filters they put on a 4020 :)
G/MAN
04-19-2007 13:45:45
 Re: 4020 diesel fuel system in reply to jimtnv, 04-18-2007 20:24:15
I must have access to the wrong 4020 info. Apparently there were unfathomable numbers of filter options according to you and Gerald, and I'm only finding three different filter numbers used total. Makes me wonder how I've gotten by so long only seeing the majority of tractors that I've worked on either having the square filter or the two spin-ons. Think I've maybe seen one or two with the cannisters. Nothing like trying to scare a guy into making two trips for no reason...
G/MAN
04-18-2007 18:30:22
You're hardly doomed to failure. But you might have to take along a few extra parts, if you can't get your uncle to ID the type of system for you before you go parts shopping. There were 3 different systems used - two that had twin filters mounted vertically above and below a common base, and one that used a single square filter. One version of the twin-filter set-up used separate replaceable elements and the filter cannisters were reused. Most of those tractors were updated to the other version, which uses two simple spin-on filters - they were/are much easier to service and far less likely to leak. If it still has the separate elements, you'll need 2 AR44077 elements and 2 R41721 o-rings to seal the bottom covers. If it has the spin-ons, you'll need 2 AR45098 filters and 2 R44101 sealing washers to seal the filter to the mounting base threads. The o-rings and sealing washers MAY be included with the filters, but they're shown separately in the parts catalog, so double-check that you have them for sure. If the tractor has the basic square glass Stanadyne filters, you'll simply need 1 AR50041 filter, and no other seals are required. Your uncle should be able to take a look and give you the run-down on what you need, but if not, you can simply get all of the above parts and returned the unneeded ones to your dealership - it happens all the time and they shouldn't mind. One other thing - depending on the type of fuel lift pump used, there could also be a sediment bowl and screen mounted on the lift pump, so you may want to take a new screen and gasket for the bowl along as well. The screen catches all the big chunks coming from the tank, and should be serviced with the final filters.
Gerald J.
04-18-2007 17:23:17
You are doomed to failure. There were several variations and I think all could have been retrofitted. Likely that's happened a few times since 4020 production ended. You can only be right if you go look first and get the numbers off the present filters.
Gerald J.
