Grind in rear-end?
txasylum
04-18-2007 05:45:54
Just a question. I see many tractors advertised and in the ad they say "no grind in the rear end". Just curious, if there is a grind, what does that mean? Are the gears worn out?
Bob
dds-inc
04-18-2007 20:22:51
 Re: Grind in rear-end? in reply to txasylum, 04-18-2007 05:45:54
beware when they say quiet transmission in an older tractor... they could've put sawdust and 50000weight oil in it!!
G/MAN
04-18-2007 17:45:30
Gear wear, gear damage, worn-out or damaged shaft or differential bearings, etc. I've seen a lot of them listed with "quiet gears", but I'd say what's quiet and what's noisy is pretty subjective, since all the old two-bangers with straight-cut gears tend to be pretty noisy regardless.
