JD 2020 gas cap and spout
Mark Westphal
04-18-2007 05:20:17
As I was driving back from purchasing a JD 2020 I noticed that the gas cap and spout that attaches to the tank was missing. How did this connect to the tank and is it easy to get back on with the tank full of fuel? The new gas cap I bought will not even match up to the hole in the top of the tank so I know something else had to be there.
Thanks,
Mark
Glen in TX
04-18-2007 09:54:13
 Re: JD 2020 gas cap and spout in reply to Mark Westphal, 04-18-2007 05:20:17
Mark, Check with Lebow-Eaton as they made most all the necks and caps for JD. Maybe someone can give you measurments off their 2020 to help you match something up. Did JD parts show any measurements for it? I didn't look yet but if it isn't completely out of their system sometimes you will still find the part listed but no price and some specs and measurements online.
Mark Westphal
04-19-2007 02:27:42
 Re: JD 2020 gas cap and spout in reply to Glen in TX, 04-18-2007 09:54:13
Glen,
I purchased what I think is the right sized filler neck from the company that you recommended. Thank you. My question: Is it better to braze or weld the filler neck onto the tank once I get it all cleaned out?
Thanks
Mark
Glen in TX
04-19-2007 09:16:22
 Re: JD 2020 gas cap and spout in reply to Mark Westphal, 04-19-2007 02:27:42
Glad they had what you needed. Originally I think they were soldered in. A local radiator shop might work on tanks and solder it in for you easily if you haven't done much of that before. I've always had good luck with body solder sticks but you need the right flux to use with it. Could probably JB weld it in too. Harder to get a sealed bead without pin holes brazing it.
Gerald J.
04-18-2007 08:04:04
Look for a filler extension for a 3020 or 4020 gas. Its separate from the tank, coupled with a hose and hose clamps. Then you need it attached to your tank.
Gerald J.
Bob
04-18-2007 08:46:48
 Re: JD 2020 gas cap and spout in reply to Gerald J., 04-18-2007 08:04:04
Those separate filler necks are pretty short.
Unfortunately, I'm afraid he'll need to find something longer for his application.
Glen in TX
04-18-2007 09:56:08
 Re: JD 2020 gas cap and spout in reply to Bob, 04-18-2007 08:46:48
Many necks on combines were longer using a hose so might find one of those to match?
Bob
04-18-2007 05:43:55
third party image
Here's what the parts book shows... only the cap, the gasket for the cap, and the "hood grommet" are shown as replaceable parts.
If you have the correct cap and it doesn't fit, the fller neck must be damaged.
Are you sure you have the correct cap?
If the neck itself is damaged sometimes a GOOD radiator shop will have access to replacement fller necks to solder in place.
Mark Westphal
04-18-2007 06:01:46
 Re: JD 2020 gas cap and spout in reply to Bob, 04-18-2007 05:43:55
Bob,
There is no filler neck. I probably did not use the right terminology. The filler neck is missing. Is this welded or pressed on and can it be replaced?
Mark
Bob
04-18-2007 06:10:12
 Re: JD 2020 gas cap and spout in reply to Mark Westphal, 04-18-2007 06:01:46
The older ones were soldered on. Not sure about the 2020... might have some spot welds PLUS solder.
Like I said in the other post, check with some radiator shops as it's NOT available from DEERE.
Bob
04-18-2007 06:10:06
Bob
04-18-2007 06:10:01
