1941 JD model B, Tricycle
E. Martin
04-17-2007 20:34:52
A friend recently purchased a very original 1941 B, tricycle, tractor. My question has to do with the boss on the upper right side of the main case that is in line with the gear shift---as viewed at a right angle to the long axis of the tractor. This boss is threaded and there is a very original stud bolt with a heavy, thick washer on it screwed into the boss. It appears that something has be bolted here in the past. Any ideas as to what bolts on here?? I have looked through sveral of my JD books to see if I could get a clue and the only thing that I could find that was attached at this location was a battery box on an industrial JD BR. Will look forward to respones and thanks.
J Durfey
04-18-2007 20:40:31
 Re: 1941 JD model B, Tricycle in reply to E. Martin, 04-17-2007 20:34:52
I want to thank all of you for your response, especially E. Martin who has kindled my interest in the old JD tractors. I will take a picture of the item in question and send it out. Who want to receive the image of the item in question?
JD
HAPPY DEERE
04-18-2007 16:08:12
sounds to me like the throttle stopper on my 41 b if you could send pictures then we could help you can email me at [email protected]
Paul from MI
04-18-2007 14:51:44
If you can post a picture it sure would help identify what you are looking for. Is this a hand start tractor? It sounds like the boss that holds the steering shaft, throttle lever, etc.
Paul
