Gene: I don't have much time right now, so you might have better luck catching me via e-mail. You can try me at [email protected] if you like. Again, without much time to compose a thorough answer, you might want to go re-read some of the previous replies that I have posted here in an attempt to get the whole picture of the reaction. Both voltage and amperage are important. Volts * amps is the unit of work we use, which is watts. The reason we all talk about amperes alone is that the chargers we use have a fixed voltage output of either 6 or 12 volts, so all we have to measure and vary is the current output. That said, never use a power supply that is over 30 volts as you can risk the danger of electric shock. I�ve written about that before. I use a 5 volt ex-computer rack-mounted power supply that can put out over 400 amps * 5 volts, so it can hit 2 KW, but at such a low voltage that I can wash my hands in the tank without turning it off. A higher voltage will help the reaction cut through thicker insulation in the way of crud and grease and such, but it takes so little voltage to get the hydrolysis of the water going, which creates the gas bubbles to form on the metal which is what lifts the crud anyway, that high voltage in the tub area is not necessary and again it is extremely dangerous. If you can get your charger to put out 12 volts it will run the reaction faster than the same current at 6 volts, but I have had success as low as 3 volts, so any common old battery charger will work just fine. Find a charger that has a good quality circuit breaker in it, and it will last a long time. If you don�t have a good breaker internal to the charger, go to NAPA or JD and get a 12 volt automatic breaker (they used them under the dashes of lawn mowers as well as the 4440 I had) and wire in series with one lead so that it protects your charger. Remember, just because a charger is rated at 10 amperes does not mean that it can maintain that output 24/7. Plan on a 50% duty cycle and de-rate your charger accordingly if you plan to run it around the clock. So just install a 5 amp circuit breaker, your charger will not work past that rating, and then adjust the mixture by adding water or moving the parts father form the electrode to keep the current draw under the breaker limit. Any way, that�s one approach. Now, the number one reason for e-tanks not working to expectation is not having enough electrode surface area. Remember: you should have as much surface area in electrode as surface area of the part you are cleaning. Otherwise, the reaction will only run as fast as the smaller of the two electrodes, the part or the sacrificial electrode. Think about it this way. If you had a "00" cable on your battery positive cable, but the ground cable is a little piece of #20 bell wire, you will not be able to pass 100 amps to the starter motor, but more like 2 or 3 amps. That�s what is happening when you use small items like re-rod which do not have near the surface area of something like a cookie sheet. Be sure you have enough surface area to pass the current you are looking for. The number two reason for lack of success is too much red rust on the sacrificial electrode, which effectively insulates it. If you are using common steel or cast iron, the rate of reaction (current fall off) will increase as the red rust accumulates. The number three reason is a poor connection of the cables to the part and/or the electrode. Reason four is the part is too far away from the electrode. The distance between the electrodes is part of an exponential equation, so the closer you can get things without touching, the faster it will run. Half the distance is like four times faster. I cannot give you a better starting point on your mix than the tablespoon per gallon guideline, but I do think you might have too much in there and too little electrode area. Wish I had more time, but that is at a premium for me right now and this is the best I can do. Gotta run. Frank
