Clooney help! 52 A oil leak?
Mike
10-12-2003 11:02:40
My 52 A's Powertrol has quite an appetite for oil. I suspect it's coming out the power shaft seal into the transmission (it's not going on to the ground), but the transmission level stays the same. However, periodically I have to drain as much as 2 gallons of excess oil out of the crankcase.
The question is, how does all this oil get into the crankcase?
Thank you in advance for the help.You've obviously skinned your knuckles on these things more than the rest of us!
Clooney
10-12-2003 12:27:52
 Re: Clooney help! 52 A oil leak? in reply to Mike, 10-12-2003 11:02:40
Mike, there a few different ways that P/T oil can find it's way into the engine. ~If you have an add on live power-Trol hydraulic pump between the governor & magneto that is probably where your leak is..
~If you don't have that add-on live hydraulic pump then there is a good chance the trans is over filling then spilling into the 1st reduction cover through one of the upper shaft bearings.
~If you have that add-on pump start there...If you don't, then try draining the trans level down about an inch or so then using the tractor to see if the trans level comes up to the full mark.
[email protected]
Mike
10-12-2003 15:57:00
 Re: Re: Clooney help! 52 A oil leak? in reply to Clooney , 10-12-2003 12:27:52
Clooney- thanks for the reply.
Don't have an add on pump and the trans always seems to keep it's oil about 1 1/2" below the top edge of the filler hole even with the PT problem.
